Flashing Active Exhaust switch
chrisp
Hi guys, bout a p450 yesterday, love it, removed fuse 15, love it even more, gone for a long drive tonight, the active exhaust switch won’t turn on now, it just flashes?
Any advice or has anyone had this before?
You’ve removed fuse 15 for the ‘Active Exhaust’ and now the ‘Active Exhaust’ switch is flashing…🤔
Yes, is this normal? Not seen it mentioned the Fuse 15 threads
Yes it is normal with the fuse removed. If you press the button with the fuse removed it flashes for a few seconds to say it can't connect then it turns off and stays off, until you press it again.
One option is to not press it as is now does nothing! :lol:
Fuse 15 controls the valves. With the fuse removed if you press the button the switch recognizes the valves aren't responding and it will flash. The switch doesn't do anything with Fuse 15 removed.
