I’ve been out in the Jag today, to a car show and noticed that it is loud all the time, the exhaust valves won’t shut!
The car is a 64 registered V6S, 2015 model year I believe. I thought it had the earlier vacuum pump operated system, but now I’m not so sure.
First, the valves are free moving and not loose or squeaking in any way. I removed the rear silencer and can’t see any issue with them.
So, I looked up a diagram on this forum from a previous thread that showed a schematic of the pump operated system. Expecting to see the pump/reservoir behind the left rear wheel arch liner, I removed the wheel and liner, but all I see is a small valve arrangement at the rear of the wheel arch where the pipes from each valve go to. It has a pipe that is taped to the inner wheel arch, disappears under the car at the front of the wheel arch.
I was expecting a pump and reservoir as described in the topix diagram I saw.
Could my car have had the tsb carried out that removed the vac pump? Any clues to this being done.
There are no fault codes logged.
