Door handle locking
Ricky's jag
Hi folks having a small issue, I used to be able to lock the doors just by pushing in the door handle on both sides, the passenger door was first to stop locking you’d push it in but one second later it pops back out, I thought I was just going crazy thinking maybe it just never locked from that side. Now the drivers door is doing the same you push in the handle to lock the car and one second later it pops back out again?!! Is there a fault or have I changed a setting somewhere?! Still locks fine via key fob.
Can you lock it with the fob?
Could be a sensor failure. Normally the car will refuse to lock if it thinks there's a door open. Does it lock when you drive away (I'm assuming you have driveaway locking enabled)?
I had that, had a warranty change of handle mechanism. However while waiting for the fix, it stopped doing it. I wonder if it was water inside that dried out.
Yes still locks when driving away and still locks via fob. So looks like a door handle sensor then. Dreaded visit to dealer then cars out of warranty and the last few visits (jaguar and Land Rover) weren’t too impressed with them.
Mine has never been able to do that, even from new pushing the door handle in just results in it popping out again half a second later, maybe it’s a dealer setting like the auto folding door mirrors? Just guessing
I’ve always been able to lock it that way, I find it more convenient than digging out the key from my pocket, the small button on the door handle still works for unlocking too.
Do you have keyless entry or no?
Keyless entry requires a light touch of the sensor/button, the geared motor does the job of bringing the handle in.
My understanding of the system is; when you drive off the handles are driven in. When you lock via the keyfob the handles are driven in and KE when you touch the sensor/switch the handles are driven in - am I correct?
If not keyless, you are fighting a geared motor pushing the handle in, which will eventually result in it failing.
Occasional pushing on the handles should be OK.
Tel said:
... KE when you touch the sensor/switch the handles are driven in - am I correct?
No, to lock with KE you push the rear of the handle (the bit sticking out) into the door, which will lock it. If you push it in twice in rapid succession it'll "double-lock" which activates more of the alarm. The handles aren't driven in at all when you lock that way - you've done it. You only touch the switch to at the front of the handle to unlock.
Is that clear or have I confused things even more? ;)
I'm going to play with my XFS when I return to the UK and check - That's KE.
The state of confusion constantly grows year on year...I love it, it's challenging...if I remember rightly!
SCM mine is KE on the spec sheet but couldn't get mine to work either.. another question for the dealer when it goes in shortly for Supercharger work. The list is growing larger by the day
Further to my previous post, I have found that the passenger side works for Keyless Entry. Tested drivers dide the same way but doesn't work either way, pushing in it justpops back out, when locked with key the small KE button on the handle doesn't open the door
Sounds like a faulty module. Mine was like that when I bought it - seemed to have been missed in the 165 point check. Luckily I tried it when I went to pick it up - the sales guy had always used the fob to unlock - and they fixed it on the spot.
Thanks ill point that out on Monday when it goes in to the Dealership
This sounds similar to the issue I have, it seems easy to take the door cards off and access parts so I can have a go at sorting myself, but would be good to know what was faulty and replaced.
