Cross member bracing corrosion warranty?
KK3960
Gents it’s nearly been six months since my purchase of my lovely 2017 AWD V8R, the car has been flawless so far and it’s second service is due shortly which has been booked in within the next few weeks.
I do have the light corrosion to the strut / cross member bracing, which I’m hoping to replace under warranty, is this now a recognised recall I can quote a JLR code to the technicians rather than being fobbed off with a wear and tear excuse. The cars only covered 15K and has an extended 2 yr warranty.
Any info would be helpful.
Thanks 👍
Recent topic here:
https://www.ftypeforums.co.uk/viewtopic.php?f=21&t=3237
Original topic here:
https://www.ftypeforums.co.uk/viewtopic.php?f=27&t=3085
On the above topic it's saying the SSM has been pulled from Topix so you might have a fight on your hands.
My car was 2yrs old in May. Went for second service and asked them to look at it and immediately they said it needed replacing.
Rebooked for today but yesterday was told parts still on back order. Obviously a bit of delay with parts and I wonder if that is why the Topic article got pulled?
If I get the service manager when I drop mine off I'll ask some questions.
Derby Jaguar have 3 on back order still. 1 being mine. If you tell your dealer the SSM number from the other posts then they can still order the parts.
Matford JLR got my parts in within 2 weeks and also V8 replacement parts for another F Type in the same window, so not sure where the back order issue is coming from.
What I did find out is, that JLR are allowing dealers 2.5 hours to do the job, which if it is done correctly takes the dealers around 5 hours, maybe that's why some dealers are reluctant to do the job?
Mine on my 2016 R AWD took them around 1.5 hours, I know because I waited in the dealership.
Having taken a look underneath not to sure where 5 hours comes from ( must include a few fag and coffee breaks).
I believe the awd parts are different parts, again I know this because on the day they should originally have been changed they had been delivered the wrong parts by Jaguar.
Mine is AWD so perhaps the back order issue is only with AWD then......
Mine was on back order since April and picked up last Friday - although there was also 8 weeks for a new engine in amongst that.
It does seem to include exhaust removal - unless on the AWD the A frame section is in more parts so it's easier to thread through everything.
Still awaiting paperwork so can't check to see if it says anything about time allowed or taken.
Not according to the SSM, different parts for V6 and V8 though:
T2R 3166 (remove) - Body Brace
T2R 40865 (replacement part)
T2R 18759 (remove) - K-Brace
T2R 40866 (replacement part)
V6/AJ200 variants:
T2P 1597 (remove) - Pt 4 Brace V6/AJ200
T2R 40657 (replacement part
V8 variant:
T2R 3438 (remove) - Pt 4 V8
T2r 40658 (replacement part)
Matford, cleaned, painted and rust proofed everything around the area including the subframe and then sprayed some form of wax into any hole or crevice.
I also waited the 5 hours and spent a lot of that time underneath with the technician
And rinsing the free coffee / snacks I hope!
Of course. And a 1 hour run out in an IPace.
The simple fact is sub standard components were used and jlr has now pulled the ssm so no more rectification work meaning any f type will in future fail a mot due corrosion of said sub standard parts
This is a fact not a maybe
Jlr shd just hold theur hand up and rectify any model affected by corrosion
Do you know for a fact that it's a fact? They haven't just pulled the SSM awaiting a fresh supply of parts?
I’ll see if I can get anything from head office on why it’s been pulled
Regardless of this not being on Topix, seems JLR are doing the repair work subject to an analysis of the issue car by car.
Mine was done after Topix was withdrawn and even my first approach to them was also after Topix was withdrawn. There did not seem to be any push back from JLR on having the parts replaced. Maybe it's the dealers that are reluctant to put the work forward to JLR?
Actually it wasn't the parts that were substandard but the zinc plating treatment, which my dealer says has been solved with the new parts, even though they covered everything with an additional rustproofing.
Dealer just called me and parts are in and booked in on 29th July. So claims are still being accepted. Maybe down to how good the dealer is? (I use Derby).
