Been lurking around the forum since ownership of my first F-Type V6S since 2016, now owner of an SVR since 2018. Had an engine management light come on this week plus an “SOS System Limited Functionality” alert which has been popping up now and then. Took it into into my local dealer for a diagnosis (£192!? just to plug it into a computer to see the error codes, when an MOT is only £55). Reported back the following:
Exhaust - “will need to install new PCM SW and retest, if fault reoccurs new cat will be req 1.0 catalyst efficiency causing EML on. Req new Catalyst (bank 2) 2.5”, quoting £1,056 (gulp!)
Electrical - “SOS warning message not on at the moment but DTC stored for antenna issue, advise roof pod for this”, quoting £278
My car is a 2017 model, with 22.5k miles on the clock. Bought it with a couple of thousand on, apparently used by Jaguar management. The included approved used warranty expired in November which I then extended for another year. Apparently neither of these items are covered by this, which is disappointing, especially in case of the exhaust issue. Apparently this can happen with the age of the car according to them, I feel this is odd having only covered the mileage I have (had my V6S from new and covered 33k over few months under 3 years).
I intend to get a second opinion from an independent and hopefully more reasonable costs, but thought I’d post here and hopefully get some of your thoughts, perhaps from those who may have had similar issues and experience.
Thanks in advance!
Thanks in advance!
