steviegtr said:Al I know is when I reverse into garage I adjust it further down so I miss my motorcycle lifter. The next time I reverse it dips down to that last position I put it. Using that as theory. Select reverse & then manually adjust the mirror back to your normal position. Then next time you reverse maybe it will stay in the position you set it. Just a thought. ?
