Spoke with Swallows Jaguar this morning and they aren't yet offering them for the F-Type but are in the process. Here’s some info from their link https://swallows-jag.co.uk/sr-brand-new-poly-bush-arms/
"Each unit begins life as a brand-new Lemförder arm—one of the world’s most trusted OEM suppliers. Where applicable, we press in polyurethane bushes for improved durability and handling, while retaining Lemförder’s OEM-spec ball joints and spherical bearings, ensuring factory-grade reliability and ride quality.
Two Bush Options to Match Your Needs
Depending on your driving style and vehicle use, you can choose from two polyurethane bush specifications:
• Road Series – 24% stiffer than original equipment (OE) rubber. Perfect for daily drivers and performance road cars, offering a balance of comfort and improved responsiveness.
• Performance/Track Series – 37% stiffer than OE rubber. Designed for track, racing, or aggressive use, delivering sharper handling with maximum chassis control.
This tailored approach means you can upgrade your vehicle’s suspension without compromising on comfort—or go all-in for race-ready performance.
Why Choose Pre-Assembled Arms?
• No need for specialist tools – Forget 50-tonne presses and complex fitting procedures.
• No need to return cores – Keep your original arms or recycle them locally.
• No installation stress – Simply unbolt your old arms and fit the new ones using basic hand tools.
• No compromise – You get factory quality parts with superior bushings, ready to fit and engineered to last.
This is a Swallows Racing ‘plug-and-play’ solution that saves time, reduces cost, and improves handling performance."
