R rogerhall33 New member Nov 6, 2022 #1 Brand new front pads for a 3.0s model, not the none S the Wife has. £25 plus postage unless you collect from Dorchester (DT3 postcode). Attachments 20221106_122213.jpg 2.9 MB · Views: 1,211 20221106_122222.jpg 3.3 MB · Views: 1,211
Topfox59 New member Nov 11, 2022 #2 rogerhall33 said: Brand new front pads for a 3.0s model, not the none S the Wife has. £25 plus postage unless you collect from Dorchester (DT3 postcode). Click to expand... Do these fit a 400S with the larger brakes? Russ
R rogerhall33 New member Nov 13, 2022 #3 Doubt it as they are for the base 3.0 whichbhas smaller doscs mate.
Lunar New member Nov 13, 2022 #4 No, they’re for an S so should do, as they’ll be for the 380mm front brakes as used on the High and Super Performance brake options.
scm New member Nov 13, 2022 #5 Unless the OP's wife's non-S has the bigger brakes? All rather confusing.
Lunar New member Nov 13, 2022 #6 Doesn’t help that the box sticker doesn’t give dimensions or mention the F. Tried looking up on the Comline site but it’s not the best for clarity.
R rogerhall33 New member Nov 13, 2022 #7 Brought another set which fit and were physically smaller so these only fit the bigger brakes.
